jestes
Active Member
Make sure it?s insurable before you buy it. If you plan to install anything other than a standard engine in your aircraft you must tell your insurance broker. They should also be asking you this at some point during the quoting process.
If you are considering using an auto engine that has been converted to aircraft use please make sure you check with your insurance broker to see if it?s insurable before you buy it. Most insurance companies will NOT insure these and if they will the premium could be 2 or 3 times more than what you would normally pay. Be sure to call your broker if you will be installing a non-standard aircraft engine to make sure it will be approved. If you do not have a broker yet please give us a call and we will answer your questions for you.
