If you use 100LL you have lead build up. There is no way to get around this. It just becomes a fact of life. There is no way to remove all lead. Decalin just helps reduce it. At 600 hrs. you are supposed to remove the gearbox (spelled out in the Line Maint. manual) and have it cleaned. At about 800 hrs. your gearbox clutch won't work any more because it will be packed with lead. I have seen many, it will be there. The clutch must be dismantled and cleaned to remove the lead. this can only be done at a Rotax distributor. Lead will deposit on pistons, rings, inside the gearbox and valve train parts.
