I'm practicing before I put actual airplane parts at risk and can't figure out how much deburring is OK. This pic shows a ridge around a hole. I have a deburring tool but it doesn't seem to take the ridge off without extreme pressure and many revolutions. I even put the deburring head in my cordless drill and it still doesn't want to touch the ridge. I have also used an oversize drill bit and that seems to work better but countersinks the hole slightly. Is that OK?
[/IMG]
Here is my practice creation. I also learned turning the pressure down on the gun helps immensely. I was running at about 60 psi and turned it down to 30 and had much better results.
[/IMG]
Thanks!!!
Thanks!!!
