skydiverlv
Do the prepunched holes in the skins need to be deburred? I feel negligible difference after debur. Sure would save a lot of time. What have the swamis been doing?
Great that will save much time. Thanks.
If they all needed deburred....my next question would have been how did you all convince your wife to debur all those holes?
We've been deburring all of the holes, though we usually only have to deburr one side. The 'bottom' side of the deburred holes always have a bit of a ridge. If they are in contact with a rib or spar, they could cause a weak spot.
In addition I'm told that the aluminum is like tempered glass, if you leave a rough edge, it'll be a spot that can induce tearing.
One other reason for deburing is to allow the skins to sit flush together without any trapped burs between them when they are rivited. If there are burs there is only a small surface area of the burr mating between the skins. This is then a weaker joint. Deburring of the holes was one of the recommendations that came out of the Comet crash in the 1950's. An ex Dehaviland airframe engineer who was at dehaviland at the time of these disasters made sure I deburred all the holes when I was a hanger brat working on Beavers in NZ many years ago.
On RV's it probably does not mater much in the scheme of things. But for highly stressed parts that flex it does.
Rob
p.s. See Robyn if you are reading this I was listening.
