claycookiemonster
Is it the weather? The phases of the moon? Sometimes it works fine. Easy-peasy. And then, without noticing anything changing, suddenly I can't get pins out at all. I've got the good Mil Spec tools from Stein. I'm using the correct WHITE one. Brand new fresh out of the package. After getting 7 of 9 out without drama, now I can't get the d-pinning tool in far enough to engage the locking mechanism. It stops with a bit of the split still visible no matter how I orient it. Am I deforming the tool somehow? Is there some way to check if it's gotten too open or too closed?
This is maddening.
This is maddening.
