aadamson
All,
I had the need to create a simple Tap for a DB25 connector. I decided to try out a new board house and have lots available. These make a great way to Y into anything that uses a DB25 connector. E.g.GPS, or other signals. They are very simple to use, you just unconnect your existing db25 and plug this in-between. Screws and nuts can be picked up easily at Frys or RS.
I will supply them with connectors - either 2 males, 2 females or 1 of each - your choice. The board presses between the solder cups and then you solder the connectors to the little board. The board has a tap point for each pin number and it's only .5 inches wide. The entire connector is only 1.5" wide when assembled. The via's will take up to 20ga wire and should support anything that we might need.
I'll sell these for $5 each or $8 for a pair (2 full sets) + $2 S/H (usps) to anywhere in the US (international if needed will be actual postage or a negotiated rate).
If interested, drop me a note with qty, gender, and I'll provide paypal information for purchase and get them shipped right out.
I've attached pictures for your reference, if those don't go thru, you can see them here.
my email is adamson (underscore) alan at hotmail dot com
As a side note, I'm tempted to do the same for db9 and db15 connectors... we'll see, I suppose if there is enough demand, I could do the big db connectors too (37 pin is it?).
