WingsOnWheels
I re-mounted my mostly complete fuel tank to the main spar today and the tank skin is setting about .023 proud of the LE skin (actually is .030 pround, but becasue of the difference in skin thickness it should be .007 high normally). The tank is completely drilled and ready for final deburr, dimple, and riveting. All the nutplates are installed and the LE is riveted to the spar.
I'm not sure how this happened, the skin was tight when I drilled it. Maybe the LE was not setting all the way down on the spar - it was only clecoed in place at the time, now it is riveted...
Any ideas or am I looking at a whole new tank?
