I thought I was CAREFULLY reading the plans for the installation of the electric fuel pump. I measured twice, positioned carefully, tested stuff, and all was well. UNTIL I went to install the motor mount!
DANG! The motor mount hits the plate nut for the fuel pump!
Am I the only guy this happened to?
We fixed the problem, but when I need to change the fuel pump, it will be a two man operation. *DANG*
I also noticed that the measurements for the throttle cable, mixture cable and carb heat cable are not very accurate. The mixture cable can not go through the middle of the fuel pump!
*sigh* I have to admit that almost ALWAYS a mistake like this is usually my fault.
CC
![2qscxgg.jpg](/proxy.php?image=http%3A%2F%2Fi42.tinypic.com%2F2qscxgg.jpg&hash=72e4d6a80fbc1dc3a4b6ea2e3b18ad39)
CC
