Dan, I have been studying base/clear painting videos cause I have no experience with base/clear, just 2k Urethanes.
They make a point that silvers ( fine metallics ) must be carefully prepared with 800 to 1000 grit before base to avoid the metal flake from accentuating sanding scratches. This does not sound encouraging for a project the size of an airplane with rivets . So, for that reason, I am thinking a nonmetallic gray might be a better path.
Your airplane is silver I think. Can you share any insight on silver base/clear related to airplane surface painting ?
