I have a D100 connected to a GTX327 and have been flying this setup for 50 hours now. I went up the other day and the tower asked if I had Mode C...Affirmative was the reply to which he replied that he was getting a good transponder signal but no altitude. Like I stated, this setup has been flying for 50 hours and I have not touched a thing and this is the first time the tower has told me I wasn't encoding altitude.
Is there a way to check on the ground if the Tx is receiving the altitude from the Dynon? When they are both powered up, the Tx indicates PA so I would assume this tells me that the Dynon encoder is working as it should or is this a bad assumption? If this in fact the case, the issue should be in the Tx. Is my thinking here logical or not. Any ideas?
Darin
Darin
