Lionclaw
I'm trying to torque the nuts on the base of my cylinders, but the cylinder wrenches won't fit on some of the nuts. The part of the wrench that wraps around the nut is too beefy and is interfering with the cylinder barrel.
Has anyone else had this problem? Should I just grind a bit of the wrench away?
I might to see if I can get a crowsfoot on some of them.
