If you intend to cut straight lines in the vinyl, it's far better to use a straightedge made from a thin strip of wood veneer. A metal ruler or the like draws too much of the heat out of the iron tip and will consequently make the process extremely slow.
I was able to find some thin, 3-ply veneer at a craft and hobby supply. Works just great.
+1: make sure the iron tip is dull and very smooth.
Pull the protective vinyl off of everything and throw it away and never look back.
I agree with Vince!
