Wouldn't an abrasive blade clog up with the softer aluminum?Captain_John said:I would do that with an abrasive blade.
CJ
az_gila said:Wouldn't an abrasive blade clog up with the softer aluminum?
A standard wood cutting blade with carbide teeth should work... I use wood cutting blades in my band saw. Each tooth just takes a chunk out of the metal...The metal hacksaw fine tooth blades just clogged up in the band saw....
gil A
