Pilottonny
Hello,
While I am waiting for my Whirlwind propeller (a very long time!) I tranfered from the FWF to installing the tail feathers, and came across a thing I find strange: The elevator horns (steel powder coated) hit against the end stops (aluminum angles) without any protection. This will damage the powder coating on the horns and whatever coating is on the end stops and allow corrosion to do its devastating work. I figured that I could protect those angles with some rubber edge-protecting-strips. However, this will reduce the up/down-elevator movement by a few degr.
- Is this tolerable? (do you need every last ? of up- or down control??)
- Has anybody done this before?
- Should I not bother and just let it bang together, ?that?s just how it works?!?
Thanks in advance for your replies. Regards, Tonny.
