aadamson
I'm not building an RV, but heck some of you on this board know that already, however, this is not an RV specific question.
I have a flap switch and a start switch (up/down toggle) in my panel and I'm trying to put the wraps on it's completion.
You can see both here in the full shot...
When connecting the wires onto the lugs of each of these, there isn't a lock type washer as the lugs and screws are either aluminum or brass. Would you add a drop of blue loctite or just snug them up good? There should be little vibration, but I figured someone here would have an opinion... ...
Thanks in advance,
Thanks in advance,
