It is now two months since my stall on take off on my first flight of the RV-12 Here is where it stands as of today.
The PSRU just came back from a Rotax Service Center...it was fine. The engine crankshaft was also fine. The oil and water radiators were not damaged, nor was the gascolator.
I replaced the two major side skins due to crinkling at the most forward ends. The four pieces that make up the underside of the fuselage just behind the lower firewall were replaced, as was the lower piece of the firewall. That piece was crinkled also, but I decided not to try to straighten it. Stainless is awkward to work.
I replaced the nose gear leg, and the nose wheel fork. The wheels and tires all all OK. No antenna damage; no spinner or upper cowl damage.
I finished replacing the lower cowl today along with the air duct. Was surprised to find the cowl duct interface (a rather small part) cost $87.25. I have a new prop on hand.
I have to reinstall the gear box and hang the eingine. That's tomorrow's work.
Then set the prop angles (lots of good ideas on that on this site lately) then do the mechanical sync on the carbs, pruge the engine, and all those little things that this work involves.
I have a small ding on the leadiing edge of one wing that will have to wait until the wings are reinstalled.
Sam at Vans sent me photos and text on setting the AST and takeoff indicator on the DYNON. He said they were going to incorporate this information in the instructions in a coming change. Their data pretty much reflects what other builders have communicated to me on this site.
I took the interium period to also install a Moeller mechanical fuel gauge.
I hope to be in the air within the coming month.
FWIW
FWIW
