Since I'll be using the 360 cowl for similar reasons, I'll be interested in the responses you get. In the meantime, I expect you'll be asked for more information, such as:
- What data are you using to base your conclusion on? IAS or TAS?
- What altitude are you flying and what is the temperature?
- Have you flown a rectangular box pattern using GPS to minimize/eliminate the effect of winds aloft?
- Have you flown along side other aircraft, in particular similar RVs to verify your are slower?
- Is your airplane completely finished?
I have a 9A with an IO-320 and an O-360 cowl. I have a 70CM7S9-0-79 Sensenich prop. My cruise speeds are about 8 to 10 kts slower than Van's published speeds. Has anyone with the O-360 cowl noticed slower than published cruise speeds?
Don, there are a couple of things to watch for that I had to deal with using fuel injection and the larger cowl. You'll need to exchange the mixture control arm on the throttle body for a straight arm. If you call Vans on this they can give you the details of who to contact for the exchange. There just isn't enough room for the standard arm in the full rich position. I also needed a longer trim cable. This is because it has to loop forward of the electric fuel pump housing. I also needed longer throttle and mixture cables. Vans doesn't mention these things so I found out the hard way. Hope this saves you some time and frustration.
Not yet. I'm finishing the fuselage and hoping there's less than a year to go on the build. Why do you ask?
We seem to have the same experience....I have a 9A with an IO-320 and an O-360 cowl. I have a 70CM7S9-0-79 Sensenich prop. My cruise speeds are about 8 to 10 kts slower than Van's published speeds. Has anyone with the O-360 cowl noticed slower than published cruise speeds?
IF the O-360 gives only gives extra 5 knots ....
and we can't get to the top of the green in normal cruise with the O-320 and are less than 5-10 knots less than the top of the green...
Don't understand Van's insistance that you don't put more than an O-320 in the 9
With our flight experience and flight date .... kinda wish we had the O-360... Remember .... Lycoming says 65% power or less for max life.....
