David-aviator
Now that things are settled down it is time to get some performance numbers before blasting off to OSH. One needs to know how much fuel it will take to get there and how much loiter fuel will remain. You never know about that place during the convention. ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Don't ask me why, but I like to cruise the 0360 180hp at 8 gallons an hour and take whatever speed it produces. A previous airplane yielded 160 knots but it was much different being a canard. I know this machine won't do that well but that's the trade off with the total performance concept invented by Van.
I took it up to 8500 as the base line and spent a few minutes on the auto pilot getting the thing stabilized. EGT was leaned to peak and then to 50 ROP, which I believe is best power (but it probably isn't with a fixed pitch prop running at partial throttle).
The GPS settled down and three runs resulted in 171, 173 and 134 which turned out to be 151 KTAS. Not bad and that's at about 52.26% power based on fuel flow at a BSFC of .51. (174 mph yielding 21.75 mpg in still air)
Tomorrow I will crank it up to 60% and 65% power (9.2 and 10gph) and see what that yields. No sense being stuck in a rut at 8 gph. The Lycoming sure can't complain about cruising at 60 or 65% and maybe the mpg won't fall off all that much. We will see.
