Surviving the Impact
What Aaron says is correct. Remember, energy changes as the square of speed. The RV9 stalls at about 43 kts with flaps and 51 clean. If you haven't flown one yet, you need to make that happen. Try stalling it. Pull power, hold the stick full aft, and steer with your feet. The airplane behaves like a canard. It would be very difficult to hurt yourself unless you impacted a tree or a building on the way to the ground. Best of all, the 9 has a glide ratio of about 12:1. If you're at 5000 AGL and the engine quits, that leaves you with over 300 square miles of real estate to look for a landing site, and you really need less than 500 feet .
Regarding rudder trim, you really don't need it. The ailerons on the RVs, unlike Cessnas for example, are designed to offset adverse yaw. Very little input is required. At the same time, the rudder area on a 9 is pretty substantial, making the plane very easy to handle in stiff cross winds. Also, the longer wingspan of the 9 results in a slower roll rate and makes the plane a very capable and stable cross country machine. Ask the guys at Vans.
As for fairings, not really sure why you'd want to fly without them. The gear leg and wheel fairings contribute over 10kts to cruise speed, with the greater part of that coming from the leg covers. Here in Michigan, I've never bothered to remove my fairings in the winter, and have not encountered any problems. Just make sure that the clearances between wheel fairing and tire is sufficient. Good luck.
Terry, CFI
RV-9A N323TP
