I have a HO-360B1B 180HP helicopter engine turning a fixed pitch prop. I hope to convert it to support a CS prop. Does anyone know if it's possible to install the plug in
the crank without tearing down the engine and removing the crank. I think it would be possible but I'm hoping someone actually knows...
Thanks very much,
Brad
Following the 360 variants it doesn't look like your engine has an option for a CS prop.
HO-360-B1B
180 hp (134 kW) at 2900 rpm, Minimum fuel grade 91/96 avgas, compression ratio 8.50:1.
Same as the B1A but with Bendix 200 series retard breaker magnetos.
HO-360-B1A
Same as C2D but with a different cam shaft.
O-360-C2D
Same as the C2B except has Bendix 200 series magnetos. First certified.
O-360-C2B
180 hp (134 kW) at 2700 rpm, Minimum fuel grade 91/96 avgas, compression ratio 8.50:1.
Same as the C2A except that it has a rear-mounted Bendix carburetor.
O-360-C2A
Same as the C1A except that it has no provision for controllable-pitch propeller.
