Smilin' Jack
I have noticed that a lot of rudders have very small cracks on them these are usually the rudders that have the AEX wedge but I have also seen them on some RV6.
Most of these rudders have a little oil canning such as I have on mine but since I am not flying or even close I am wondering about a possible fix to prevent this oil canning of the rudder skins. I noticed this after the rudder was built and ran my hand down the side of the rudder. At about 2/3 the way from the tip to the base i noticed the oil can effect with my hand sliding over the rudder. I have seen this on every RV I have come across.
Since this is the area of the small cracks. I was wondering has anyone used the small hole in the bottom rib to insert a plastic line about a foot and a half into the rudder and use some expanding foam to fill the cavity between the skins. The weight would be minimum and it would only be needed in that one area. If when adding the foam you placed a 2X6 on top of the rudder skin to keep any possibly of expansion of the skin. I think this would be a viable option to prevent the skin from cracking in the future.
Any advice on this would be great. I figure the time to work on this is while I am waiting for the wings.
Smilin' Jack
Oh by the way the wings are due to be here on 5/16
Smilin' Jack
