I had noticed cracked paint arround the windows of quite a few RV-10's, so I tried to followed instructions on here and applied a layer of fiberglass cloth with epoxy over the seam. I was very pleased with the results and it was crack free for a year. We used Weld-on 10 to bond the windows. At Airventure with the canopy cover off for a couple days ( I always like to look inside other aircraft and appreciate not having them covered up) cracks appeared (obviously a big mistake, but I'm sure the same results would have appeared later). I don't know if this is an inevitable occurance without a canopy cover in the hot sun, or if I did not install enough glass. I used one very thin layer,(don't recall it's weight) (still have some left).
Unless this something that will re-occure I'm going to need advise on the exact procedure and redo all arround the windows. Our canopy top is white, (base coat clear coat) and I hope repainting the top will not be a nightmare?
Seeking advise.
Ron
Seeking advise.
Ron
