I'm working on the window. That seems to be going okay, but one step involves marking from the inside where the roll bar brace brackets interfere with the aft edge of the plexiglass so you can trim it to fit. I did that step and it all went well, but I was not 100% happy with the centering of the window, so I did the whole thing over again. In my second attempt, I was kneeling on a stack of towels on the baggage floor and felt something give.
The result is a dent in the F-01447-L baggage floor just behind the hole where the rudder cable passes through and a crack from the inside corner up to a point next to (but as far as I can tell, not intersection) the rivet on the innermost of the K1000-08D nutplates. Pictured below with lots of bright light to make it look as bad as possible. The dent is enough that the F-01440 seat ramp has a slight gap in between that nutplate and the next one outboard, but it's not very bad.
I am worried about the crack. All advice is welcome. Replacing the baggage floor, while technically possible, would be a real headache because it would also require removal of the baggage side walls and rebuilding of the seat bottom hinges, plus about 10,000 LP4-3 rivets, 4,000 nutplates, miscellaneous other work like redoing the baggage tie-downs, and painting the interior on that side all over again. But if replacing it is the right thing to do, it's just a few dollars in parts and a few dozen hours of lost time.
Here's my shame, bare for all to see:
![](/proxy.php?image=http%3A%2F%2Ftheari.com%2F%7Eari%2FF-01447-L-crack-thumb.jpg&hash=e7be3f2e5b0dd8bed46cb97cd28173de)
