I have two CPI units factory programmed for conservative settings. When it is time to optimize them per Toolbuilder's CHT/MP observation protocol, is it OK to make changes on one unit in flight, and then modify the second unit to match it?
My reason to do this is space limitations suggest a temporary mounting to access the CPU for experimentation, and then permanently mount it with the second unit in the avionics bay . I don't anticipate fiddling with the units once they are reasonably and conservatively set for my engine and fuel preferences.
