GuinnessGuy74
I'm New Here
I have a CP-214 Pneumatic squeezer that has an air leak. This obviously prevent the tool from reaching max pressure. For those of you that have one of these or have repaired one, maybe you can help me?
The tool is leaking at the throttle valve. I am talking about the valve that is pressed in by the lever when you depress the trigger. I have taken the head assembly apart. Everything looks ok. The gasket on the swivel connection looks bad, but it is not leaking there. I replaced it with a thin o-ring anyway. The other o-rings look good. If any of these were bad, I'd think that the tool would leak air when not being used.
On all the assembly drawings I can find, there is an o-ring somewhere on the throttle valve around the safety bushing. This o-ring isn't on the outside is it? That bushing looks like a machined fit to the valve. No place for an o-ring on the outer surface, or inside as far as I can tell. Anyone know how to remove the safety bushing? Is it pressed out?
Here are the exploded views I can find:
https://www.ustool.com/pdfs/US114%20Series.pdf Page 8, part # 9 and 8.
http://www.store-planetools.com/index.asp?PageAction=VIEWPROD&ProdID=184 Part # 81 and 55.
Any help is greatly appreciated. This tool will squash a AD-3 rivet with no problem, but wont even dent an AD-4.
Jim
Jim
