I am working on the cowling and just installed the top half rear hinge that you replace 1/8" pin with the .90. I am not crazy about the .035 slop in the cowl that you wind up with. Has anyone done anything with cam lock fasteners on this assembly? It would seem that cam locks would give a much more positive hold and eliminate the constant movement in flight. It would be nice not to have to reinvent the wheel here if someone has some advice.
Thanks.
Thanks.
