skyking902001
I'm working on fitting the front cowl--using Dan Horton's method. The nose of the cowlings appear to be offset--there is about .65" difference (measured at the edge of the cowling) between the left and right side--same for both upper and lower cowling parts. I assume the nose is supposed to be canted--just wanted a sanity check before I proceed further. Thanks in advance.
