I've replaced the 1001Q lower hinges with solid plate.
I've riveted the 1001N upper cowling hinges to the cowling per the plans and I'm about to rivet the 1001P side hinges to the lower cowl. (All parts of Step 8 on 47-6)
Follow-on steps refer to checking/marking/cutting the side cowling split lines, which involves installing/removing upper and lower cowls in this process.
OK...unless I go ahead and jump forward in the plans and make the cutout in the upper cowl for the hinge pin retainer, how does one insert/remove the upper cowl hinge pins with the lower cowl in place? Any tricks in this process?
David
David
