jay.pearlman
I am installing your skybolt fasteners in the cowl of an RV that I am building using the James cowl. For the top half of the cowl at the firewall, I drilled the cowl fastener holes to 15/32 rather than the 1/2 inch recommended in the sky bolt plans. The grommets for the retainer 1/4 turn screws seem to fit well in this size hole. Is there any reason I should drill out the hole to 1/2" as suggested in the skybolt instructions?
Has someone else done the slightly smaller hole?
