DakotaHawk
My RV-7 with IO-360 with vertical intake Airflow Products has interferance between the mixture cable/arm and the side of the snorkel. I've tried to make a stand-off to move the mixture cable toward the centerline about 1/8", but still can't prevent the interference. It only happens at full rich position - maybe the last 5% of cable travel. I'm using the stock cable support sold by Van's for the throttle/mixture cables.
Has anyone else had this problem? Figured out how to solve it?
I've considered glassing in a bubble on the side of the snorkel to provide the clearance needed. It would only have to be about 1/2" to give good clearance.
I've checked my cowl for alignment and that's not an issue.
Thanks in advance.
Scott
RV-7 N957RV
Arlington, WA
Thanks in advance.
Scott
RV-7 N957RV
Arlington, WA
