The cowling is supposed to be held together at the front by a aluminum strip, riveted to one half and screwed to the other. Is there any reason not to use a piece of hinge instead?
I used Rolled Hinge Material from F16 throw-away stock on my RV4 and it worked well for 1500 hours...much stronger(Acft Spruce sells it). My Rocket has screws through the plate and also works well...your call.
A lot of early builders had these hinges crack, and hence the change. The -4 has rather different cowl geometry than the -6s and that might explain your better luck keeping them intact....
