gabbiesrv7a
Member
Is it just me or am I missing some more detailed info for the cowling installation. Drawwing 45 is the main drawing, but there is little if any description on step by step (general or detailed) information. Im not sure if I am to start to fit the lower cowl first then the upper or vice versa. does it even matter. Also, as i am leaving the forward skin off for easy access to the panel area, will I have problems with just clecoing the main 1/8 hinges to the firewall flange, so I can cut and trim the cowl or must the hinges be riveted. thanx, keep on keepin on, gary
