I am fitting the engine cowl. I temporarily fitted the prop, measured everything up and made a plywood disk to simulate the back of the spinner - so far, so good.
However, from what I can see, there is no support for the cowl forward of the firewall. This seems to mean that you have to ensure the front of the cowl is VERY accurately taped to the wood disk so that the rear hinges hold it in the correct position. Even having done that, the cowl doesn't have any internal bracing and the whole thing looks a bit "wobbly".
It seems almost inevitable that I am going to end up with cowl droop - or am I missing something?
Incidentally, I am using the stock hinge fitting.
