PeteP
Final fitting my lower cowl today and discovered that the right exhaust stack only has about 1/2 " clearance between both the engine mount and the cowl no matter how I rotate it. The left stack has about an inch clearance. It is the standard Vetterman exhaust and a 9A mount and the cowl has a good fit to the fuselage. Have other encounter this and is there a method that I have not discovered?
