Hello, We have started the lower cowl attachment, we have four clecoes holding it in place and the lower cowl just barely touches the back spinner plate, when we attach the top cowl to the bottom cowl we have the desired gap at the spinner plate. Does the lower cowl flex outward when separated from the top cowl, just thinking ahead as I have seen first engine starts with top cowl off and the lower cowl not touching the spinner plate. I have sanded just a little past the firewall scribe lines and don"t want to sand any farther because of the inner cooling tunnel fit to the oil and water radiators. Anyone have this problem? Should I sand some more or take some off the back spinner plate? Thanks Don Lewis
