E. D. Eliot
Section 18 - flaperon. I am about to rivet the parts of my flaperons together. Question is - is there a 'cover' for the outboard end of the flaperon assembly? I have two unused A-1210s which look like they could be forced into position on the outer ends of each flaperon but not without considerable 'massaging' of the parts. Are these meant to cover the outer ends of the respective ailerons? What am I missing in the instructions?
I have looked thru many builders logs and can't see a clear answer to this question - most everyone has construction pictures of the inner end on the flaperons - not the outer ends.
Thanks.
Thanks.
