Mike.Smith
Active Member
I am starting a second hand -9 empennage kit. It appears that the previous owner got as far as match drilling the HS, that?s it. I clecoed it all together and identified 5 holes that were missed. I did that by removing one Cleco at a time and putting a rivet in the hole ( thanks John). Everything is good except for a three holes nose rib/spar/rib. These three holes the rivet is pretty tight, it goes in, but it?s tight. Should I redrill the tight holes? Next question, how the heck to keep the parts straight after you prime them? Any pointers are appreciated.
