countersinks
120 degree tooling is available, but almost everyone uses the 100 degree tooling when the occasional cherry rivet is used. Vans approves this as well. If you are substituting a large amount of cherrys with the intent on using them throughout the airframe, then it may be wise to invest in the proper 120 degree dies and c'sinks.
Hope this helps...Chris
