Aiki_Aviator
I am up to the point of countersinking the VS-1003 spar and given that it is sandwiched between 2 pieces of aluminium, what is the countersking depth meant to be. Vans states that it should fit the skin, however as a test, is that BEFORE?? Obviously it needs to be flush AFTER riveting. The skin is dimpled, fitting into VS-1003 (countersunk), and laying on the spar doubler (i.e. niether countersunk or dimpled).
My belief that there can be some clearance before as the riveting will 'squash' the pieces together. Is this correct??
My question is, relative to a setting a 426-3 rivet flush with the countersink, is the countersking more/less and by how much (i.e. microstops if available)??
I have been testing various combinations, however I do not have scraps of the same thicknesses, So I am just fumbling about. Any help welcome. Thanks in advance.
