Countersinking on the rear spar assembly
On page 14–03. In figure #2, countersinking the lower section of the W - 1207B (spar doubler plate) other than the holes required for the CS 4–4 rivet, do I go ahead and counter sink, the two outboard holes, and then counter sink the hinge bracket hole? I see those will require the CS 4–4 rivet in the next section .
Thank you for your response in advance.
I believe so. I didn’t have any issues going forward. My wings are completed but not fitted to fuse. Here’s a pic of mine. Note I over countersunk the outer hole. Go slow, remove cage from part and test often… I got greedy and went for it in one swoop and the shoe of the cage wasn’t as level as I thought. But I left it as is since it was tight after riveting and the countersink hole wasn’t larger than the material thickness or rivet body diameter.
It’s interesting that prior to November of 2018, all of the sub-spar rivets were LP4-3s, so no counter sinking required. Wonder what prompted the change?
Hmmm. Don’t know how much clearance I’ve got, but mine don’t rub. Guess I screwed up during my build. :)
Mine (LP4) are very close but don't rub either. This is the flaperon in the full up position. I can understand why they changed the design.
