I'm on page 31-03, step 5, machine countersink the faceplate of the fuel selector valve to fit the screws (ms24693-c273). The faceplate is not flat and I'm not too excited to freehand this, since it will be out in plain sight for everyone to see. Anything less than perfect will be noticed. Well, at least by me.
I'm wondering if anyone has any great ideas on this. I'm going to see if I can build up the area to create a flat surface. This was done on the flap brackets and it worked fairly well, but this seems a little higher and I'm not sure if my cs cage will go down far enough. I'm hoping someone has an easy suggestion or I'm just not seeing it. I'll check the CS cage depth, but thought I would throw it out there.
Jeff
Jeff
