Hi,
I currently countersinking the #30 holes for the horizontal stabilizer.
Are the two countersinks on the picture below meant to be in the spar HS-903, instead of the doubler plate?
I am talking about the two marked holes with red arrows.
Is this the correct side (in the spar) to countersink those two holes? I am nearly sure that it is correct as I understand that they have to be countersinked to allow the HS-911 Hinge Brackets to be placed... but on the other hand I found the spars to be rather thin to countersink. It is just that I don't want to mess up the two spars.
Thanks!
Thanks!
