While assembling the W-314 aileron bracket of my RV-7 I countersunk the wrong side of the bracket for the 2 AN426 rivets just bellow the bearing (DWG 10A).
Is it safe to countersink the other side as well and rivet from the correct side? I have done this and the shop head almost fills the countersink hole on the other side just like riveting the trailing edge of the rudder. In addition, I drilled a third hole lower but centered between the pre-punched holes for extra support.
Is this ok?
Juri
Is this ok?
Juri
