AX-O
All,
I am trying to collect data on how many folks are running a constant speed prop with a counterbalanced crank and without a counterbalance crank. depending on the results, I may be working on a project for a constant speed prop (flight test). If you care to provide feedback, reply with one of the answers below. If you care to ellaborate on #3 (if that is your selection), that will deeply appreciated.
1. Counterbalanced crank and constant speed prop.
2. Non-counterbalanced crank and constant speed prop. No prop issues/failure.
3. Non-counterbalanced crank and constant speed prop. Some prop issues/failure.
Thank you for the feedback.
