Doing an inspection on a newly purchased 450 hour RV-4. Found cracks in the aluminum plate that attaches the air filter housing to the throttle body. I have drawn the cracks on the plate. This wasn't far from failing. Further, the bolts that held it onto the throttle body were loose (not wired or even lock washered). Will make a new plate out of 4130 and powdercoat it.
I understand that had this failed I would have suffered a serious loss of power, but more worrisome is the potential for fire if the fiberglass filter housing got pushed against the exhaust pipe(s).
![Throttle%20Body%20Plate.jpg](/proxy.php?image=http%3A%2F%2Fwww3.telus.net%2Fpublic%2Fmolsons%2FThrottle%2520Body%2520Plate.jpg&hash=28de55df23c4f77a173e7c854b0a5f32)
