alpinelakespilot2000
Can't find references to these tasks in the manual:
1. When do the corner baggage ribs get drilled to the side skins and riveted to the bottom skin?
2. Since the center bottom skin overlaps the conical bend on the aft portion of the fwd side skins, how is the baggage rib to sit flush on the bottom skin between the bulkheads? Is it not supposed to or will something be serving as a shim under the fwd portion of the corner rib?
Thanks.
Thanks.
