gmcjetpilot
Cool new electonic filter device
http://www.miracleantenna.com/Smoothie.htm
This baby does it all. One thing that I found interesting according to the manufacture is sometime electronics like engine monitors can make noise and 'pollute' the electical system. It protects from transient voltage and a massive OV. This may be the ticket if you want peace of mind, to protect your fancy EFIS. It is also has adjustable volts. Some electronics may be happier at say 12.8 volts than 14.5 volts, which just makes more heat. The only limit I can see is its good for only about 4 amps, so you might need two to protect all your expensive goodies. I might put it on my Comm, Intercom and EIS4000 engine monitor. My transponder is an older Collins with no voltage protection, so it might benefit from this device as well. My Dynon EFIS is suppose to be spike protected. I suppose this device would allow you to keep avionics on during start, which might be handy for engine monitors and EFIS. However I probably would continue to follow my practice of avionics off during start.
![SmoothieMarketgrad.jpg](/proxy.php?image=http%3A%2F%2Fwww.miracleantenna.com%2FSmoothieMarketgrad.jpg&hash=6a2c3254393c8855ffb266a001ec9261)
