Flutter/Snatch burble different things / "oil can" normal
Had a friend who is knowledgeable fly my 7A today it has 4 hrs and a heavy wing (left) he tells me that he experienced some flutter @135knots and after (slaping) the stick the controls didnt come to netural properly He says the bottom of the right aileron has some severe oil canning about 2 feet that could be causing the problim, and that the aileron should be re riveted on the bottom side with heat to stiffen the skin. I have no Idea what to do. I didnt slap the stick when I flew it, but I didnt notice this at all Any sugestions????? Marc
Marc I am not going to attack your friend but is he a trained test pilot? Has he ever flown a RV before?
He sounds like he may be getting neutrally stable and flutter mixed up.
The TEST pilot slap is not looking for the control stick to not center but to actually GO further and/or snap back and forth in an oscillation which eventually left could go full-stop to stop.
At high speed full deflection would damage the structure almost assuredly, whether pilot input or flutter induced. Your test pilot buddy saw the stick stay over..........THAT IS NEUTRAL STABILITY NOT FLUTTER.
If he thinks it will react like a piper or cessna it will not. RV's are not built to FAR's, which is why they have light and enjoyable controls. There is no LEVEL-O-MATIC super positive roll stability. There is plenty of roll stability for safe flight while maintaining a great feel.
Doing a slap test is a serious thing and should be done with a parachute. If your buddy was not ready to bail-out, than that tells me he does not know what he is doing.
#2, 135kts is not fast but is over (Va). The ailerons are fully mass balanced. You balanced the ailerons before you installed them and did RIG them per the manual? It all has been figured out. There are 5000 RV's flying. Van is an engineer and has over built this thing in every aspect.
COMMON CONSTRUCTION ISSUE
Not saying this is your problem, but some RV'ers miss build their control surfaces and don't bend down the radius flat and leave a bulge at the trailing edge. That can cause all kinds of weird feel and heavy wing. In fact just pinching one aileron just ever so slightly will cause your heavy wing to go away, totally like magic.
First check your ailerons are in rig. Than make sure your control surface trailing edge radius is NOT to large.
Last I don't know if he tried to push the stick full deflection at 135kts. Va is 123 kts I recall.
COMMON IDIOSYNCRASY - Aileron burble
FYI - There is a known idiosyncrasy of RV's with full stick aileron deflection for a roll (below Va of course); at high deflection (high roll rate, large or full roll input) you can feel "snatch" or burble in the stick, at full deflection is normal for RV's. This is not flutter, just air separation. Some planes near stall, turbulent air off the wing hits the tail and it can be felt through the elevator. It is normal. This is not what you describe, but just FYI
Flutter is a different thing.
NOT RETURNING TO CENTER IS NOT FLUTTER NECESSARILY. I JUST MEANS NEUTRAL STABILITY. RV's ARE NOT CRUDDY CESSNA'S THAT HAVE LEVEL-O-MATIC. You can put a RV into a turn and it will stay there. It is a fighter plane not a truck. RV's can NOT be certified by normal part 23 FAR because they handle to well. The FAR's call for positive stability. Positive stability means you have to fight that to make it maneuver. RV's are mildly positive but not so much you feel it.
Control deflections will stay put when you let go, verses returning to center. This is good and why they FEEL so good to fly.
Flutter tends to be a buzz more than the ailerons or elevator not returning to neutral. However flutter left too long or severe could result in a large uncontrolled (by pilot) deflections (eventually full stop to stop deflection) and destruction of the airframe.
But putting the aileron over with a slap and leaving it, where it stays there is NORMAL.
It is possible that ailerons are not "rigged" properly, causing them to deflect or hunt and no return to neutral.
"Oil Can" is normal normal normal if built to plans. I have seen and heard it on factory planes. As a former structural engineer oil can and diagonal tension are normal. You can make oil can free structure. Guess what? It's very heavy. The amount of oil can does not affect the controllability.
Webb Willmott "Aileron Dismemberment"; That is a nice failure theory and it may be true, but severe structural damage can occur to the wing spar, failing the entire wing structure, not to mention a jam and loss of control.
Flutter is not good and can be fatal. RV'ers have had flutter and survived (
they where WAY OVER Vne), which is a testament to the design. The pilot reports a buzz. If it got so bad that the control stick went full deflection at high speed, you will likely fail the structure.
The famous and late Steve Wittman died with his wife in a plane of one of his famous designs. He used fabric techniques incompatible with the fabric system he used. The wing fabric started to de-laminate. Due to separation of the fabric, flutter occurred and loss of airframe, Steve and his wife Paula. (A small oil can on an aluminum control surface is not a fabric surface blowing out.)
http://www.ntsb.gov/ntsb/GenPDF.asp?id=ATL95FA092&rpt=fa
http://www.ntsb.gov/ntsb/GenPDF.asp?id=ATL95FA092&rpt=fi
Bottom line if you build your RV to plans it is VERY safe; if flown with in the limitations of the airframe, which are well established, you are safe. RV's fly more hours every year (what 5000 RV's have flown?). There is no issue with flutter. Most if not all airframe failures I have seen in 20 years with RV's has been due to gross overload (too fast pulling too hard) or builder construction deficiency.
