jscottpilot
Active Member
The number 4 bolt that holds the front and rear control sticks onto the control column will not fit inside the bushings. If i drill it quarter inch it will then be to big. What is the proper way to enlarge a bushing where the bushing does not rotate around the boat? Has anyone else had to enlarge this bushing to fit the bolt?
