denbobp
The builders plan requires the control column to hang freely after install. My hangs freely until I tightened the AN 3 bolts throught the square spacers into the floor structure. I've widened my holes through the square spacers but it doesn't fix the issue. There seems to be a few ounces of friction so I don't know if this is considered acceptable????? When I move it by hand it stays in place rather then return via pull of gravity. A concern during flight is there any twist in the airframe that might cause that friction to multiply? Thanks for sharing any ideas with this issue.
